iceman17
Hi folks I am using a Spektrum DX8 transmitter and AR8000 receiver with my F550 and totally forgot that the radio came with the TM1000 telemetry module. I want to hook up the telemetry and use the included voltage sensor to monitor my pack in flight. Question is can I just solder the sensor ends to the bottom plate power pads on the 550 to get the proper voltage reading. I am using a 3 cell 5000 Mah lipo battery made by Traxxas and they have a Traxxas connector so I can use them in my RC trucks as well, I find the Deans connectors to small for my fingers to grasp. Next week I will be receiving an AeroXcraft F550 landing gear set along with their Gopro 2 axis gimbal for my Hero2. When I build and mount everything will I have to change the settings for my GPS Z setting, right now its at -10cm, with the gimbal and landing gear and camera combo it should change the CG quite a lot I would think. Looks like it might be difficult to try and find the CG with everything installed, how do you guys with Gimbals do this. Thanks in advance,.....................Mike
