SamaraMedia
I saw a photo the other day of a hexacopter that had three motors facing up and three motors facing down alternately around the craft. I've never seen that configuration before and wondered of the pros and cons of the setup. On one hand you could probably get away with running larger props since the tips would not hit as they would in a traditional setup but wondered if it would matter if the larger props would cause an undue amount of prop wash or would I be better served running a Y6 config to be able to use a larger motor prop combo. Right now I'm a little under 800mm so I'm limited to a 14" prop without hitting tips.
Thanks,
John
Thanks,
John
