Hi, not sure if this is the best place to post this.
I recently set up from new a M470, flashed the firmware to 2.2 and went through complete setup with props off. checked i could start/stop motors etc then went for a maiden flight, just a low hover, quick check that left,right, forward, back were all working etc. i then lost all control of the craft and it just hung there 5 ft off the ground (luckily stable and not moving) while i frantically tried to work out what was going on. eventually not sure how it can down (hard but no damage).
Took ity back to the bench, props off and plugged in the software and i had no bind at all. re-binded and it all appears to be ok again although i have not got any confidence in it to try another flight. Any ideas?
Thanks in advance.
Thanks in advance.
