vulcan2go
That is a typical error message when the pole count is set incorrectly...... based on my personal experience.
Not seen that before - useful to know!
Ronan,
I assumed you were using the latest firmware which is: 2.42b7
not b6.....
First you have to replace your GUI with the latest - from the BaseCAM web site.
I think you will find it works a bit better.
I have to dig into that again tonight..... forgotten a few detailed steps.I have the board mounted on the vertical 'rear arm' with the lipo. The other board is mounted on the bottom of the plate, which is of course located bellow the yaw motor.
Is there a specific/better way when i CALIB.ACC and CALIB.GYRO to give better results?
Best to avoid recalibrating the accelerometers after they have been done correctly.
Just recalibrate the gyros.....
Also with remote control of pitch and yaw, adjust them to various angles and listen for any buzzing at specific angles. If you hear any, it is a resonant frequency that needs to be dialed out. To determine which frequency, install an app on your smart phone or program on your PC that is called a spectrum analyser...... several are free for PCs.
The program will use your device microphone to listen to your MR. You should see a peak in the spectrum at the frequency you need to dial out. Once you know the frequency, use your BGC GUI to set up a notch filter for that frequency...... it will nullify the buzzing so that your camera will not show the vibes in your photos/videos.
[MENTION=6734]gtranquilla[/MENTION] Hey mate, i'm still getting drift of the yaw axis... After about 3-4 minutes, the camera doesn't point forward anymore, it's already made almost 200 degree turn (slow & steady).
Still a gyro issue?
Both the acc and gyro calibration is a pain... I have to 'block' the gimbal so it points perfectly forward and is level, do the acc calib and then i need to immobilize the whole thing to do the gyro... i think i'm not doing it right...
I'm so close though... darn!
I'm using 2.5 firmware now but I'm pretty sure that the GUI for your version has an expanded page in the RC control tab - just scroll down and you should see itI just upgraded to the new firmware version 2.43 b6 from previous 2.42 b7 and noticed that the GUI has removed the RC control of Yaw motor.....
Do you happen to know why and/or where it went?
Otherwise the system works fine.
