NerV-Runna
Hey everyone, I need some advice with regards to a custom build octo.
Im building an octo frame that can carry a droidworz slr camera mount, hence quite a payload including the camera.
I want to use the following motors:
C2836 KV880 Aeolian
The specs are:
Rotational Speed: 880 (kv) RPM/V
Continuous Current: 22A
Max. Current: 28A
Input Voltage: 6 - 14.8V
Max. Efficiency: 98%
No Load Current: 1.2A
Internal Resistance: 95(Omega)
Power: 490W
Motor Weight : 85g
Motor Dimensions (Diameter x Length): 28mm x 36mm
Propeller Dimensions: 11 x 8.5/ 10 x 7 /12 x 6
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Will 8 of these motors work?
G
C2836 KV880 Aeolian
The specs are:
Max. Current: 28A
Power: 490W
Motor Weight : 85g
G
