MombasaFlash
Heli's & Tele's bloke
Don't quite know where to put this (no funny suggestions please) as it addresses points raised in two other threads about Droidworx battery and HDMI converter placement. So I'll just start another one.
I too was unimpressed with the Droidworx battery solution and so, as I already had a bunch of flat packs for the MK Octo, I opted for the same MK method and piled on three bays. Two for flat LiPo's and one for the HDMI converter.
Of course, this is no good if you want to use a PhotoHigher camera mount. For that you need to use the DW Double Battery Tray that attaches directly to the Gear Rails - but then it has to be LiPo bricks.
I have an AV200 being slowly prepared as an alternative but will face the same problem of where to put the HDMI converter if the NEX is used. When I come up with a bright idea I will pass it on. Personally, I do not like FPV cameras or anything that is not directly showing the recording camera's view because a) framing is always guess work and b) you won't know that there is a problem (like, you forgot to switch on the main camera or the battery went flat 5 seconds after lift-off) until the flight is over.
The pics below (apologies for them all being a bit soft and crappy) show the multiple MK battery bays for LiPo's and HDMI converter for the NEX and all the pretty lights. The brilliant Superlights, white at the front and the red and green at the back, along with the boom mounted LED's, are excellent for long-distance orientation (thanks to Droider for alerting us all on that one a few months back). I do not like front boom LED's due to the risk of flare on the camera lens. The front mounted white SuperLights are set inside shades to shield the lens below from glare (sculpted Kodak film boxes - what the hell are we going to do now they have gone bust? I use those film boxes all the time).
The video at the end was shot yesterday morning with this exact setup. I had to get out and capture the incredible light and mood of a clear, frosty, winter's morning before Spring arrives. BTW, I want to 'paint' myself out. Does anyone know how to to do that? Is there a video equivalent of the Photoshop Clone Tool (for Mac)?
Moving across from an MK Hexa to a Droidworx AD3X-HL and I find the way to attach the battery seems less secure and slower to do than the MK....
... I have a downlink working but it requires a HDMI to Composite board ... etc.
