DJI Innovations
DJI is going to release a new firmware for A2 soon. Check the below new features.
What is new?
Firmware
1, Support of both PC and iPad Ground Stations, providing 50 waypoints for use. To utilize the Ground Station function, please connect the Air End of the Datalink module either directly to the port labeled ‘CAN2’, located on the A2 Controller unit or the ‘CAN’ port, located on any modules which are already connected to the ‘CAN2’ port using a CAN-Bus cable.
2, Support of a remote configuration feature by using the DJI Assistant App on iOS through Bluetooth.
3, Support of the DJI Zenmuse H3-2D gimbal.
4, Option to dedicate nose or tail direction to point towards Home Point while performing the Go-Home procedure.
Assistant Software
1 Option to dedicate nose or tail direction to point towards Home Point while performing the Go-Home procedure on the Failsafe page. The tail of the aircraft points towards Home Point when performing Go-Home by default.
2, H3-2D channel added to the Channel Mapping page, specialized for the H3-2D gimbal pitch control.
3, Channel Mapping button added to every page for convenience.
What is new?
Firmware
Assistant Software
