Hexacrafter
Manufacturer
The Radio signal was there the whole time until he turned it off.....
You can see his attempts to turn off failsafe in the log... 43 seconds into flight 10 or so times into ATT mode.
It spooled up in Manual Mode with U Channel (RTH) and POI turned on..had been powered for ONLY 21.683 seconds....too short for a GPS lock.... just 6 satellites...
Flight mode switched from Manual Mode to GPS mode at 21.705 second.... GPS /RTH & IOC kicked in and tried to RTH.
IOC was also active... this can be VERY problematic as well...disorienting.
Once GPS/ RTH has taken hold...TX is locked out until.... shut off by switching to MANUAL mode (Or ATT in position 3 if programed this way).
He never switched all the way to Manual Mode- Position 3 of switch, so he was never able to regain control.
But he appeared to still be in U+ mode, so if he would have made it all the way to manual, it would not disengage until the RTH switch was disengaged.
As I cannot confirm via the LOG data that any GPS homepoint was recorded.... and I do not know if the A2 will record a homepoint when in failsafe/ RTH mode, I am just guessing that it was trying to fly to a previously recorded homepoint..... I have seen this before.... to many times....
This is why the Data file from iOSD or any flight logging is so helpful.....
It takes away most guesses and relies on data....
In this case these above mentioned facts are just FACTS....
Very unfortunate...
Regaining control during an incident like this would be VERY trying..... too much going wrong all at the same time with panic setting in....
I can imagine....
Very unfortunate...
I can imagine....
