Tim Marchenko
View attachment 28022 View attachment 28026 View attachment 28027 View attachment 28021View attachment 28022 There is 8 motors in a bunch. Never used. The seal is broken because I was about to build a octocopter but never got to it. I will take reasonable offers. $650 is already at $350 discount. Ill sell individual motors at $90 each.
With multi-rotors widely used in many fields there are more requirements for high quality power systems focusing on unparalleled reliability, durability, high power and high efficiency. The U5 motor must operate in extreme climate conditions, so the performance must be designed waterproof and dirt resistant. This is why U-Power was born. To meet the customer's rigorous demands. With over 18 months of research and development, we release U for the UAV market.
German engineered
Self-cooling system
Options for three mounting prop method
Single thick copper wire winding
Adapter for 8mm size prop
Waterproof, dirt resistant
Silicon steel
Specifications:
Voltage: 6S
Recommended Props: 15x5 or 16x5.4
Take-off Weight: Hexa at 9KG and Octo at 12KG
KV: 400
Configuration: 12N14P
Shaft Diameter: 4mm
Motor Dimension(dia. x len): F42.5×37.5mm
Weight(g): 156g
ldle current(10)@10v(A): 0.3A
No of Cells (lipo): 3-8S
Max Continuous Current(A)180S: 30A
Max Continuous Power(W)180S: 850W
Max Efficiency Current: (10-18A)>84%
Internal Resistance: 116m?
German engineered
Self-cooling system
Silicon steel
Specifications:
Voltage: 6S
KV: 400
Shaft Diameter: 4mm
Weight(g): 156g
