snurre
Just to add to Snure's post, make sure when you're flipping the switch to record the POI that you end in the OFF position. Alot of folks misread the instructions and assume when you finish recording the POI the switch should be on...that is incorrect...must be OFF. Move your distance away then switch it on.
Good catch! Maybe that was the mistake I did a couple of days ago when I could not get it working... :frog:
