3D printed FPV quad
RTRyder
Merlin of Multirotors
I've recently acquired a 3D printer and one of my first projects was trying to make replacement arms for the less than sturdy Delrin parts of a HoneyBadger FPV frame I have...
None of those were due to hard crashes, all it takes is a rough landing on a hard surface to do that kind of damage and after replacing too many arm pieces I retired the frame rather than keep buying more parts. The solution it seemed was a set of arms made of 3D printed ABS plastic...
Although I assembled the frame with a complete set of ABS arms I never flew it that way. Once I started making 3D printed parts I thought why stop there, I'll try making a complete frame. This is the prototype of what I ultimately refined into a very nice flying FPV quad...
One thing quickly learned in this whole process, you rarely if ever get it right on the first version of a part, there's always some little tweaks that need to be made before everything fits together properly and works as it should. The final version incorporating all the little tweaks doesn't look much different but the folder full of CAD files on my computer suggests there's plenty of unseen changes...
Even this version has had some refinements, the video TX/camera mount on the front proved to be no good so the current setup is similar to that of the original frame.
The black and orange frame weighs in at 170 grams bare. I haven't yet weighed it with all the electronics and motors installed but I do know it flys 15 minutes on a 3S 5000 pack, landing with the battery right at 80% discharge, so it's significantly lighter than any of the other FPV quads I currently have flying.
The red, white, and blue version will soon get rebuilt to include all the changes made since it was built. Currently it is flying with a Multiwii Pro board with GPS and the black and orange has a Naza Lite. On the bench is another frame I'm building for the owner of the LHS also with Naza Lite, it will be interesting to see what he has to say after flying it.
I'll post some more recent pics and video after the weekend flights at the field.
deluge2
Thanks for the pics and description! It will be interesting to see what your experiences are with the small squadron. What 3D printer and what CAD sw are you using? Any comment on the approximate consumables cost for the whole airframe?
Steve
airship
really nice frame!!!
can i ask you with wich 3d printer you have done it? it seems to have a nice and clean finish...
also, regard the derlin , i play a lot with it on my little cnc machine and i always have found it really strong, probably in my opinion there are a problems with the drawing of the frame; each hole or try to light and cut must be done in the right place.
RTRyder
Printer is a Solidoodle SD3. Currently using Sketchup for CAD since it seems to be what a lot of other SD users are using and there are a lot of designs done in it that can be customized. Eventually I'll change to something better when I have the time to learn a new program, Sketchup exports to STL often need to be run through Netfabb before they slice properly so better CAD might eliminate a step or two.
I haven't added up the filament required to make all the parts but I doubt that it comes to more than a couple dollars at most, the screws to hold it together probably cost as much or more than the filament it's printed from.
Flew both of them a bit today but the wind was blowing fairly hard and I called it day early, I did find the Naza needs some gain adjustments, that will get taken care of next time out.
philg
Nice mate,I like to see someone making there own frame with this technology.
Looks good as well.
RTRyder
Here's a pic of the orange and black completely outfitted and ready to fly...
Working on a couple new things now that this one is fairly well sorted... :)
