2 Axis Brushless Gimbal DSLR size camera
RC Rotors
THE RC ROTORS EVOLUTION 2-AXIS BRUSHLESS CAMERA GIMBAL IS DESIGNED FOR PROFESSIONAL AERIAL CINEMATOGRAPHY.
Universal camera mount. Will fit most cameras like a Go Pro, Sony NEX 5N, Sony FS100, Canon 5D Mark III, Black Magic, the Red Epic and many more. Lightweight and high performance, parts are mainly carbon fiber.
Gimbal shows minimal flex under heavy loads.
ADDITIONAL FEATURES:
· Max. Width of the camera: 160mm
· Max. Height of the camera: 130mm
Constructed using rigid 25mm carbon tubes
· Fully adjustable for CG of camera
· Fully adjustable for height of camera
· Top or bottom mount camera
· 5mm thick carbon camera plate
· Hard coated aluminum shafts
· Dual ball bearing roll axis
· Dual ball bearing tilt axis
· Simple removal from Multi Rotor
Scope of Delivery: Assembly required. No motors or controller included. $400.
Purchase here http://www.shop.rotorsandaerialmedia.com/main.sc
I also have a few alexmos controllers in stock (viacopter edition) motors will be here next week. design is based on the i-power gimbal motors. for now you can use the 5206 and 5208 for either roll or tilt. 4008 to come later.
RC Rotors
Dry weight of 2 axis gimbal is aprox. 460 grams
add 170g for each 5208 and 146 for each 5206.
the gimbal is fully adjustable for fore and aft and camera height. this is the key to having the system work correctly. it should work with that camera.
SMP
While this looks like a very nice gimbal it must be clearly stated that this DOES NOT come with controller or motors and to my knowledge no one has come out with a Brushless combo which will accommodate anything over a DSLR (and even this is still under development) certainly not a RED. So.. Nice Gimbal, NOT a complete solution.
