Balmybaldwin
So, brand new here as ive decided to enter the world of flying objects. First of all I want to learn to fly a quad, with the eventual hope of getting a fully featured camera platorm of the ground complete with fpv etc. Apologies for the lengthy first post!
After a bit of research(although evidently not enough) I have chosen a dji f450 as my frame as this seems fairly versatile. I went for the artf version with motors and escs included.
Tutorials ive seen all say the motors have their direction of rotation marked on them. The ones that came with this kit dont (the ones I have are dji branded 2212/920KV) any ideas? Do I assume they are all the same, and just reverse the connection leads? (speaking of which there are3 all black with no labels)
Does it matter what lead from the motor connects to the u,v and w sockets on the esc? I presume they are 1to1 the way they emerge from the motor? But what about the 2 reversed motors (see above)
Why with £500 of kit have I not got instructions or at least a wiring diagram with any of it?
Ive googled a lot of it inc a step by step video of a f450 build which means I at least know what to solder where etc but I assume that I should worry about weight distribution etc...whats the best way to check cog, and I assume its better for stability to have a lower cog? And does the fc need to be on the cog?
Which brings me to the other boxes ive just unwrapped:
dji naza-m v2 with gps (again no sign of an instruction booklet)
Devo 10 tx/rx
Lipo 3S 11.1v 2250mah x2 (i actually ordered one 3300mah but got these and a y connector!)
a. B65a+ balanced charger
The naza im ok with after viewing tutorial vids, only question is on vertical position in the quad.
The batteries and charger worry me I keep hearing stories of them going into meltdown and taking out a radius of 5 miles. Is there a good dos/donts document around? The "instructions" indicate I should plug in a balance plug before attatching the main power leads to the charger. I assume this is the little white 4pin plug attatched to the battery? Charger itself seems very complicated, and I last did anything rc when nicads were the power source of choice so any help would be apreciated!
Also if some one can point to the relevant regs for the uk i'd appreciate it, I assume flying in fields etc isnt a problem, but imagine they get jumpy if you fly over the local raf base?
I think thats it for now.... time to start soldering stuff![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Many thanks
Ed
Devo 10 tx/rx
Many thanks
Ed
