+ and - pads on flamewheel lower frame plate
Hi everyone,
Can someone please tell me if the + and - pads by the battery attach points actually have power (with correct polarity) available to them?
Bart
yep, there really nice. top and bottom are pcb and split pos/negative. Think it handles around 50-60 amp current. There should be the same pads at each arm to feed each esc
A digi multimeter on the pads orientated red pos, black neg should show a positive voltage, if so, your set. negative voltage is reverse polarity on mine anyway
i shipped the F550 yesterday after putting LED's to those contact points. Mikrokopter has similar pads on their power boards and I didn't even think that they might only be non-functional labeling until after it was in the mail. the new owner was advised to double check for polarity before plugging the lights back into the leads so it all should be good to go then.
thanks! <sigh of relief>
