Oh I see. So it will hold altitude better the better its dialed in.Vertical gain is the amount of correction applied to maintain altitude hold, to low and it wont hold, too high and it will overcorrect, overshoot and oscillate
Ok, maybe that was the problem. I'll check to see if it works tomorrow. Also set the vertical gain to 160Yeah thats right, it should be checked 'come home and landing' and also if you want to be able to select RTH you need to adjust your channel5 (U) so the slider lands in the failsafe position instead of Manual.
Great link!Check out 'Naza Gouge' JG, its a good source of info for the Naza
Best to do it outdoors, away from the electrical sources inside.Does it matter if I do the calibration indoors or outdoors?
	Well that didn't go well.
Brought the quad up in gps mode, started toilet bowling really bad! Like a 12' toilet bowl circle. Ended up going into the grass about broke a prop. Didn't even get to check the failsafe.
It didn't do this the last couple times I flew it. I adjusted the location of the gps and entered the values in, -4cm, -4cm, -9cm. I'll take a picture of the gps location just so one of you can confirm I have the right measurements.
also was looking throw that naza rouge......is the center of gravity from the top of the baseplate to the gps module, or does it start below the baseplate. I have it set to -9
Have you turned your GPS antenna n the right direction for your local magnetic variation?
If GPS misbehaves go to Atti mode, fly for a while then go back and figure out what is up with GPS mode. I usually take off and land in atti mode.
Turn it left about 12 degrees.
Yes it will help.
With my 450 and my 550, it takes a while until GPS settles down, I have a lot of trees where I take off so the reception is not the best here. Often I get a bit of TBing in the begining of the flight, but once I have been up for a while and I get just a steady green blink it stays within 2-3 ft even 4' above the ground.
Yes it will help.
Just checked. The top of the naza is 2cm below the top plate. The distance between the top plate and the center of the gps puck is 9cm. This mean I set z at -11? Maybe I'll just do -10 as a happy mediumI think the 10 cm is from center of gps pod to the top of the naza housing which on the dji frames (disco included) it's about 1 cm from the bottom of the top of the frame (if that makes sense)...at least that's how I did mine but I didn't use the mast.
