plasticjoe
I just resoldered all 18 bullet connectors tonight... mercy I hope that solves the issue !!  I'll test it tomorrow
			I had exactly this issue with my 'stock' F450. Mine turned out to be - I cable tied the ESC's to the DJI arms too tight (put the cable ties around the middle of the ESC and round the arms. This slightly bowed one of the ECS's which have under the heatshrink cover a metal heatsink plate. Because of the overtightened cable tie it had caused the plate to short on one of the board components - but only occasionally and randomly!!
Dale
You may have just solved a similar problem I'm having.
How did you verify that the ESC was shorting, or did you just assume because the problem want away after removing the cable tie?
Jack
Hi jack - the problem doesn't neccassarily go away when you remove the cable tie because the damage (bending of the inner heat-sink plate) has already been done - although it may allow it to spring back a little - replacing it if you have identified it as your problem is the safest way. (the formula is: 'replace x1 relatively cheap ESC = potentially saving entire expensive Quadcopter')
Dale
Jack - read above posts ...... identify failing motor - check solder joints (unlikely if you took care) - check bullet connectors (possible) - very unlikely to be motor itself - (and unlikely to be Naza) = ESC
