Adding 2 servos to Naza using Futaba T8FG + s.bus
Below is some first flight videos of my F550 c/w Naza GPS. Landing pad is a 4 x 4 foot corrugated plastic panel (landing pad) to protect the Hexacopter from snow! My stick handling is still a bit jerky....
But now I want to configure/add two servos for a camera. Once I get those working I will order the gimbal system. Anyone knowthe best wat to add and test two conventional servos when using s.bus and configure the Futaba transmitter?
http://www.youtube.com/watch?v=jNlzUXAGDNU&list=UUWjXtmmJ9xJcdyahNA7pwPA&index=1&feature=plcp
I'd use the naza camera gimble outputs, but you want to add a bec for the servos. I had decent luck with the castle ccbec 10 amp who ****ie
You can hook them up straight to the radio. It'd have to be on two unused channels. i use ppm so your result may differ but ch5,6 are open on mine but i don't use any gain knobs.....
Thanks Kloner..... I am a bit confused about the necessity for the 10 amp BEC so I am going to repost with additional detailed information re: my RC and Naza which came c/w with the VU, i.e., V-sen voltage regulator/distributor. If of interest, please see my reposting which will be completed momentarily.
