Zero UAV ZeroUAV YS-X4 Owners Thread
robone
I thought I would add this here so we can separate the two systems:
Product Overview:
The YS-X4 FC is a continuation of the zeroUAV product innovation, practical, simple style and using a highly integrated IMU control board
The new All in one design is stylish appearance, has a full metal texture with free navigation, guidance and point navigation, point lock features, while supporting a variety of terminal ground stations and adapt to all kinds of frames.
The Ground Control Station comes free with any of the systems purchased and is available in Android or PC versions
Wifi Version
1 Auto (Takeoff/ Go Home/Landing)
2 Target Lock & Fly encircle (Both ground station and RC Transmitter can control &
No limitation)
3 Click/Touch & Fly To Point (Unlimited times, 30 meters Point to Point max, 20 sec
wait per completion for next point)
4 Realtime Flight status (Google Earth Map)
5 Auto-Navigation(4 waypoints + 200m Diameter Max)
6 Fail/Safe (Auto Hover–Go home–Landing)
7 Low Voltage Alert
8 Gimbal Stabilization
9 Flight Control Mode(GPS Atittude Mode/ Atittude Mode/ Manual Mode)
10 Wifi Module
11 Built-in Damper Module
12 Optional S-BUS/Ordinary/PPM Receiver
13 Carefree
14 Follow Me
15 Intelligent Motor Arm/Disarm
Navigator Version
1. Features as per Wifi version
2. Target Lock & Fly encircle (No limitation)
3. Click/Touch & Fly To Point (No limitation)
4. Auto-Navigation (8Waypoints + no range limitation )
Basic Characteristics:
Supports multi-rotor aircraft type
+4, X4 type Quad
+6, X6, Y6, Rev Y6 type rotor
+8, X8, V8 Octo (unavailable for Gimble)
Recommended remote control
PCM or 2.4GHz
At least 6-channel or 8-channel
Failsafe and support all channels
Supports ESC with a 400Hz refresh rate
Recommended type of power: 3S ~ 6S lithium polymer battery
Power consumption : Maximum 2.5W
Operating ambient temperature : -5 ° C to +60 ° C
Assistant Software system requirements: Android / Windows XP sp3 / Windows 7
Flight characteristics
Hover precision (GPS mode)
Vertical direction: ± 1m
Horizontal direction: ± 2m
Maximum tilt angle 35 °
Wind resistance <8m / s (17.7mph)
Maximum vertical speed 6m / s
Components:
1 WIFI module X1
2 main control board (MC + IMU) X1 (Black / Silver)
3 GPS module X1 (Black / Silver)
4 Power Module X1
5 LED lights X1
6 GPS bracket X1
7 Steering gear of wiring X8
8 USB cable X1
9 Warranty Card X1
10 Stickers X1
11 cable labels X1
Bluetooth is available as an optional extra
robone
Some of us are going to be having two ZeroUAV systems. ZeroUAV support have told us how we can link the two systems to one router. Not tested yet, but as soon as I get my YS-X4, I will.
To set the Router up so that you can use one router with a number of Auto Pilots:
Say you want to use one router with a YS-X6 and a YS-X4
The wifi of ys-x4 default work mode is router , that mean it need use with the router . the SSID :ZERO-TECH password: 82890430 so you need setup the router : SSID and password the same as the ys-x4 wifi mode .
Then you need change the wifi mode of ys-x6 .
If the led of wifi mode is blue , that you need use the router , to change the wifi SSID and password .
If the led of wifi mode is red , that you can use the wifi config software, see below, to change the wifi SSID and password.
Then you can use one router .
http://multirotor.co.za/?page_id=964
Kari
mongo
lost soul
aanybody happen to know, who the dealer for zero stuff in the US is. maybe even have a link?
robone
I have just connected the YS-X4 wifi module to the same router used for the YS-X6
So while it is still fresh in my mind, let me try and tell you what I did.
I connected to my router using the SSID for the YS-X6 that I have. Found this to be the easier solution.
Changed the SSID on the router to ZERO-TECH
Connected the battery to the YS-X4 wifi module
Ran Wifi Config.exe
Pressed “search” button – top left
Once it identified the wifi module then hit button “get config” bottom middle
It then loaded up the wifi SSID in the top right centre
I then changed the SSID to YS-X6-serial number. (whatever your YS-X6 serial number is)
Pressed apply button on the bottom
Then went into my router and changed the SSID back to YS-X6-Serial number
And that’s is it. Now both are connected to the same router using your YS-X6 SSID
I did try and do it the other way around, but I was not successful. This works for me, so thats all I need.
Rob
robone
I have just taken my wifi version YS-X4 out for its 1st flight. Used my android tablet in Hotspot mode to check the settings and calibrate the compass.
The flight was really just to check the settings and see if everything was calibrated and setup correctly.
But, wow....this is good. Took off in manual mode and it was a perfect take off. Did this a few times. Then took off in Auto Pilot/GPS mode flew around in this mode and it was brilliant. Let go the sticks and it sits. This is exactly what I want for flying FPV. Landing in GPS mode is a breeze.
System used:
Frame: CarbonCore 500x4
Motors: MT2216-11
ESC: RC Tiger T30A
Props: APC SF 10x4.7
Auto Pilot : ZeroUAV YS-X4
As a flight Controller, this is superb. Chucked it around and it handled extremely well.
I haven't tried the RTH or any of the other features yet, but knowing the YS-X6, I am sure they work just as well.
Excuse the ESC's just hanging around. They are going to get packed away now that I know everything is connected correctly :)
Rob
robone
Anyone know if you can get this in the UK?
Paul
I normally do not like selling to people outside of my Country as it is difficult to provide a good support and also shipping costs are high, but if you want me to, I will be prepared to sell you one.
Rob
nice to hear some first impressions!
a general question because you mention fpv
I am big fan of simple and minimalistic setups and also as little things to set up for a shoot as possible
so is there a reason to fly this big wifi module around? ok for tuning its nice to have, but after?
I am not intrested in wayponist or anythink more complicated then dynamic position hold and retur to home
I have a battery warning already through my video link....so all I could think of is loss of gps warning ...couldnt that be outputted to a buzzer somehow? yes ...I fly with audio :)
thanks
Tuomas P.
Just tested the YS-X4 on an X-8. The setup pretty much out of the box. It seems that once the altitude hold is on while flying in altitude hold mode or GPS mode, the motors start to oscillate. Its restless. Actually my YS-X6 does the same. Tried to put the values down, but its still restless. On the manual mode its much better (video from 0:28) Any ideas? Here´s the video:
https://vimeo.com/54954528
Rgds,
Tuomas
Pjtyros
Rob
Hi Rob, seems to have moved on a lot since the Xaircraft days, thanks for your kind offer, I just had an email from a UK supplier of the X6 but they are not sure they will carry the X4.
Paul
robone
Paul
Please don't remind me of those days :upset:
Its a pleasure. IMO they are making a mistake if they decide not to stock the YS-X4.
Anyway, let me know if you are interested, and I am sure we can make a plan.
Rob
robone
thanks
I have never tried, but I am sure you can remove the Wifi module. I never fly with it either. I only use it to have a look at the battery voltage now and then.
robone
Here is a video showing position hold posted by KariY on RCGroups forum
