Simiban
Flying-copter.com
Hi @ll
Flying-copter.com is pleased to introduce new (almost
) multi-rotor structure.
The TORNADO PRO SERIES has been developed for areal shooting at low altitude.
Everything in the TORNADO PRO SERIES is optimized for best results and reduced weight that will allow our models to obtain flight clearances required for any profetional work.
Each carbon element is isolated from direct contact with another to avoïd vibration propagation.
Our arms are foldable without any tools. The arms mount system allows an easy positioning for flight, transport or storage. To secure the unfolded position, a very simple and light weight system prevent any movement of the arm once in flight position.
The engine mounts are integrated in the structure of a single piece, from the machining. This is to prevent mechanical element added and screwed with all that vibration may cause.
Storage and transport of multi-rotors is always problematic. Flying-copter.com finally is pleased to offer a range of products that are extremely easy to transport. With a ratio 1:2 between their unfolde:folded positions, our TORNADO PRO SERIES will allow you to carry where want your multi-rotor with minimum bulk size.
Being ourselves passionate users of multi-rotors, we try to avoid some disadvantage often encountered. For the deployement of our multi-rotors no tools are required to fold/unfold arms. No screws to remove, what kills the risk of loosing a screew out there... Our system are robust and very reliable. All Made in France with European materials. No cheap fake low cost component are used. Only some ISO factorys.
The result of several month of work
And here the case fully packed with necessary stuff. 2 Propps are un mounted, to gain some place.
Hope you will enjoy !
Regards
laurent
Regards
laurent
