hoveringal
Hi friends - I need your assistance, expertise and assurance that how I have my quad set up will provide the desired results pertaining to the RTH mode. I am scared to death to flip the switch and test it... I completed the Flame Wheel 450 quad and have conducted several succcessful flights. She hovers, climbs and flies very stable and takes excellent video from the Go-Pro mounted underneath. I am using the Woo Kong FS unit with a Spektrum DX-7 transmitter.
When connected to the "On Line" Woo Kong Assistant all values react properly. I can toggle from ATTI to GPS to FAIL SAFE via the three way switch on the transmitter. I had to eliminate the M mode on the switch which was cool since I never used it anyways. Each flight mode is displayed on the WK Assistant when the switch position is changed. If I turn off the transmitter the WK assistant shows it going into FAIL SAFE mode and adjusts the throttle to just below 50%. All other flight controls remain centered.
Here's my concern: Is "Fail Safe" actually RTH mode with an active signal from the transmitter? At this time when I flip the three way switch to the RTH position, the craft goes into FAIL SAFE mode but does NOT affect the throttle. If I shut off the transmitter the craft goes into FAIL SAFE and adjust the throttle to 50% (or just below). All other flight controls remain centered. Does this sound right ??
And finally, lets say I climb up 50-60 feet in GPS mode (which should give me ATTI & GPS modes for a stable hover) then flip the three way to FAIL SAFE / RTH, if the quad goes nutts can I recover and regain stick control by switching back to GPS mode hopefully before impact????
Thanks for reading this and helping me - I am sure you can feel my apprehension to flip the dreaded switch but just cant wait to see her fly home and land.. I gladly welcome any/all advice you guys may share with me... I will report back after I get some posts....
