given the history of the kits, it's probably what he said..... resolder the bullets to the wires and try it again. if that motor continues to run like that, then start swapping around the motors and see if it does the same to another motor. it is somewhere along them three wires, it's just hard to say which three's intersection. it can be loose in the motor, the fet in the esc can die...
the bullets get bad solder from the factory is a known problem from dji, usually on the motor side to bullet. there solderer is a new guy or something
