GotHeliRC.com NEW! Gem Fan 1045 Carbon mix (direct fit with DJI motor)
GotHeliRC
http://gothelirc.com
you really gotta look hard and imagine what the right picture is showing, the keyed hub,,, it'd help if it was shot over white to contrast and show the dji hub part.
whats your feelings on the quality? the hub looks thin from here...... is there 6mm shims for the top of the prop to sit on the threaded part? any shims?
GotHeliRC
Hi Kloner,
Attached two better picture.
Hub is 10mm thick, about 12mm wide (digital caliper is acting up). If you start from the top down, top is 6mm (2mm deep) then it step bigger to 8mm (notch cut in and 5mm deep) then the last portion is 9mm ID 3mm deep... The 9mm ID is because on the normal GemFan they come with prop adapter.
So plenty of material for strength.
ElectricSheep
Looks good, and the price is right...
What's your take on the prop's stiffness? How does it compare to the Graupner props?I know that the Graupners cost much more, but had to ask anyway.
Thanks!
Tapatalk on iPad
sure would look more solid if they cut the mold rail or whatever they call the thing on the side... Are they all like that?
edit, crap, just looked and there only $2........ ok
GotHeliRC
Yup...
I bet you they would hand file it, buff it, if it was 10.00 each. Or I can do it if you want... :D But unfortunately, it's only 2.00
Don't try that with a stock DJI prop! I bet you it would snap with a 1 lb. weight!
I just received my set from GotHeliRC and I must say that these props are quite good, especially for the price! :cool:
