You will want to keep the entennas seperated on the tri pod. usually we measure stuff in wavelengths and usually at least one wavelength of seperation is the norm for most antennas. the 5.8 wave is 3.33333" ..... and so on.
honestly, i've never seen this done, keeps us updated. Yes the stronger gain on an antenna is alot more powerful than a higher power transmitter. they say anything over 500mw is too much,,,, i use 1 watt, the legal limit here. i have one 500mw in the telink, same lawmate product,,,, looking back there wasn't a whole lot of difference between it and my 1 watt just using 3 turn helis.....
this is the two, the big pile of gravel that i dive down at the wash is a 5000-6000 feet away, the big open field i fly to next, looks like an abandoned development at the end of the houses is 1 mile from where i was standing and all this was through trees you see when i launch
everything else the same except no eagle tree osd
this is the 1 watt, stats on screen
same ground station, same 3 turn, 2 different planes with different power. the later has alot better seperation but i also found when i got home the left rear lobe on the cloverleaf was broken at the shield side,,,,,, i expect a cleaner signal next time
when is say seperation, it means the part on the craft, all of em
a zII has like this
see al the wire between each piece and how far apart they are. Thats an osd, logger, video trans, rc rx, gps ant, esc spread around a 56" wide wing
then you get a quad and it's like this
the red and black wires lead to the eagle tree logger, barometer laying up against the flight controller, other side has the osd laying up against the controller, then the video and rc antennas are about 12" apart. not much seperation
then this is a f450, all the same stuff
all tighter and closer together. with uhf, this one didn't work very well at all. too close, no seperation.
this is the plane in the top video, great seperation for the components, why it works so good
