Sunny Sky 2814 motors mislabeled?
2tall
Fly Often - Fly Safe
I can't tell for sure from their photos, but it looks like the motor shaft is 4mm, and the prop adapter shaft is 6mm.
maxwelltub
Yup, your right. I never saw anything about the diameter of the prop adapter. I assumed the prop adapter was the same as the motor shaft but I see my misunderstanding now. Thanks for your response.
maxwelltub
I was thinking about it. I have an AG-550 gimble that I want to use with a 550D. I know under normal circumstances your wouldn't do 4s with 11" but given the added weight...?
it's written on the specs for your motor.......under normal, the heavy load is 3s with 13's, says good for 3-6s,,,,, 370 watts is alot
Kari
I think they are same as qc3328 and i have ran qc:s with 13x6.5 props and 4S and motors are barely warm in my 5kg hexa.
maxwelltub
Im not sure I fallow. I you concerned with the amount its drawing off the lipo? I wanted something to match the Avroto motors but was slightly cheaper. Those are rated at 350. These specs also say standard prop size for this motor with 4s is 11x5.5.
