Hi folks
First many thanks for all your feedback so far, but I am still struggling with this. I have even gone back to 2.01 and the 1.6 assistant, and still have problems.
Some background first may help,  This quad is an X format built up from an older Xaircraft 525 frame, using the old flamewheel arms as extended legs, and the flamewheel  power plate to distribute power. The motors, ESC's etc are all original flamewheel.  Control is of course the MAZA MC and PU.
This setup was working when flying as a flamewheel, but the frame was too small for my needs, hence the 525 frame. The all up weight of her right now with lipo, camera etc on board is only 1450 gms.
I have created a brand new acro model in my DSX9, centred all TX trims, subtrims etc etc.  I have full movement, or dead close to it, in the assistant control page.  With this setup, I can suddenly get the motors to start with my old and normal method of both stick in at the bottom.  So far, so good.
As you push the throttle up,there is little action from the motors for a while, and then at around 15% they speed up until just over 50% throttle.  Then that's it, it just about is getting light on its feet, and there is no further throttle.
It is certainly not getting anywhere near full throttle. I am running 10 x4.5 props.
If anyone wants pics or even video I will be more than happy to do one ?
Thanks again
Ian
The monitor in my radio shows the throttle going full travel in both directions.
I just put a new AR9000 on to test the RX and have the same problem, so that rules the Rx out !
