rdalemercer
Jameshk,i got download naza 1.6 software....and the wire connection got picture or diagram ar?for s-bus..i really confuse with s-bus and normal connection..
Are you able to fly you MR now? Are the channel assignments correct? If not, you will need to go into the FUNCTION menu on your Futaba and reassign the channels for your S-Bus to match the stick movement. I had the same issue. I had the HS 6014 Rx and everything was fine - but the S-Bus does not line up correctly AETR like the HS6014 did.
I am not in front of my radio at the moment and won't be until later tonight, but I can send you the the assignments that I made in my Tx (MZ14). Again, yYou will need (want) to confirm that they are correctly assigned in the Assistant once you have them set for your sticks so you can confirm the movement is correct or it will not respond correctly.
Regarding the 'wobblies', as Kloner suggested, you will need to change the gain setting until it smooths out. Be sure that your props are balanced and that you have the MR balanced on the CG.
Dale.
