S800 Z15 and groundstation not possible ?
fritz99
Hello !
With S800 and Z15 there is no CAN Bus port free to connect the downlink hardware to the WKM.
Has anybody any idea how I can connect the downlink hardware ?
Fritz
At the moment its not possible with the 2.4ghz module, only with the 900mhz since it has two can-bus ports ! DJI will release a Can-bus hub though pretty soon ! Are far as I understood the OSD unit that is coming also need a can-bus port. So even the 900mhz owner will need the Cab-bus hub if they want to use the odd.
Didn't announce anything ! Speaking for it is it that the NAza is probably the preferred FPV setup. Speaking against it is that the WKM differentiation toward the naza is already very little. If you don't want an octo or Waypoint or use a zenmuse the Naza will do. So lets hope they don't consider the OSD to be another feature update that should strengthen the argument to buy a WKM
i'm holding off buying any osd's till they tell us. if it's reading inside the units gyro for AH, using the dji compass/gps, that is just too much cool to not buy. I'd take three right off the bat
cloner remember the NAB movies of the Ruling the DJI remote and the OSD they showed on it. I am pretty sure that this was the beta OSD.
min 0:44
looks good
