DJI Service Bulletins
fvg007
Yes..I did have RC helicopter and airplane experience, so I can tell I know what I am doing here.
I bought the unit as a complete build by dealer, all I suppose to do here is to install my radio ( I fly Mode I - Asia style which I dont see this can be a problem )
This is why he told me he test flight the unit before ship out.
ah okay i thought he test flew the naza only.
One more guess the lipo protection. What is it set to 4s or 3s ? and the values. Maybe its going to safeguard descending because its set to 4s and you are using 3s ?
fvg007
I have gain set from 100% - 250% using a VR switch but no luck...The video you see here is running around 120%.
I do notice at high setting ( over 200% ) I can see some oscillation of up and down - motors are rev up and down...
fvg007
This is my Lipo setting here:
Will try to turn it off and see it make any different...
Mrk172
And I'm sure you have no throttle curves programmed in your TX that would throw your throttle position off at the 50% setting. All mixes off as well. I'm sure you've checked this but I'm just trying to rule out possibilities.
fvg007
I did fly it until I got the battery warning - red flashing light show up.
Dont see anything different in handling ....
fvg007
Did couple test today...problem comes back!
1 flight: turn on lipo protection and camera gimbal on - System does not work. height cannot hold and motor will not stop in 3sec after startup
2 flight: turn off lipo protection and camera gimbal on - system does not work.
Both time I calibrate compass before flight.
3 flight: turn off both lipo protection and gimbal which was my last working setting...But still does not work!
I cannot get it back to esc turn off in 3sec after startup!
Any idea..? Now I am confused!
