kevinv033
My first build log ever. Whoop! Hopefully, this is helpful to some folks.
Close up of the power distribution pads
I installed my motors first since I have long motor leads. I then soldered the motors directly to the ESC.
I am using Hobby King F-30A flashed with wii-esc.
The motor mounts accept 16mmx19mm and 25mmx19mm mounting patterns for motors. There are also mounting holes for NX-4008 motors. I am running Avroto 2814-11 (770kv)
This is the center of the PDB plate. It has pads for the 4 ESCs. On either side, there is are pads for battery leads. You could easily add pigtails to both sides and run two packs in parallel.
Prior to installing the lower frame spacers, I added a dab of loctite blue to all metal-metal screws.
Install all short (10mm?) spacers.
I've shortened up the battery wires so the ESCs fit neatly between the two plates. There isn't much room down there. My F30A just made it. I am sure smaller ESC will be fine. I am not worried too much about cooling. The ESCs haven't been more than slightly warm to the touch. I'm pulling ~14A in general flight.
Soldered in XT60 pigtail and installed G10 plate. Next up is mounting the arms.
Bottom frame complete.
