This guide is very handy in order to make sure you've doen everything you need to do to have your Hoverfly Pro flight controller all ready to go.
https://hoverflytech.zendesk.com/entries/21202158-how-to-setup-autoleveling
My question (for Ben
) is, is it normal when going through the steps to have to reset everything multiple times throughout the process even where it's not spelled out that a poweer cycle is necessary? I find that when I go from tab to tab in the Setup client, the status will go from Connected to Not COnnected. In trying to follow the directions in the above link (for example), I find that if I first disable the Accelerometer Calibration, I can't just go to the next step without cycling power, closing the setup client, and then restarting everything yet it doesn't mention this in the guide. If this is just kooky HF stuff and the heli ultimately flies very well then that's fine and I'll just do what I have to do. But if these quirks are avoidable, especially for people that are both new to Hoverfly AND new to multi-rotor heli's then let's get this worked out and keep the head scratching to a minimum.
on another topic is there a list available yet regarding acceptable servos to use with the Gimbal?
THanks (Ben),
Bart
THanks (Ben),
Bart
