Good going!!! Glad we got it sorted. You are in for a lot of fun, my friend.
The wobble can be because of a few things.
First off, you mentioned wind, so you are going to see that happen as the motors compensate. Depending on the wind, the worse it is the more wobble you will notice.
There are a few things you can do to help yourself out, though.
Props need to be finely balanced. Even changing to a different manufacturer of props can make a huge difference. You've read all the inqueries about Graupner's. APC makes some very good props for a hell of a lot less. However, before you worry about props get your's as well balanced as you can get them. Watch some vids on how to do this.
Basically, a Dubro prop ballancer works very well and is not expensive. You find the heavy blade and scrape material away from the back side of the blade and then finely sand it with emery cloth to a smooth finish. Never do this to the top of the blade, this is the working surface. Myself, I take some emery cloth and break the fine sharp leading edge, also. That razor sharp edge doe's you no favors. I just remove enough so it isn't so easy to cut my fingers is all. It does make a difference.
Next would be to check your motors balance. There was a post a week or so back about an app for a smart phone that works well. There was included a vid on how to do this. In the video it showed the guy adding tape to the light side to eliminate vibes. This works, but you risk throwing off the tape, or at least pulling an edge loose.
I would take this one step further, myself. After discovering which side is the light side I would then mark the light side and take a file and remove metal from the heavy side until the vibs were down. This takes a lot of time as you need to do this in baby steps. You can always remove metal but not add it.
This kind of makes the motor look ugly, but I would rather live with that trade-off.
The foam flapping on the bottom isn't doing you any favors, either, so loose it.
I like the spring metal landing gear that the 500 uses, it's just not long enough for your application. Me, I would look for a metal working shop locally and get a length of spring steel from them and make my own, or have them cut them to length and curl the end so it doesn't try to snag anything on take off.
I would stay away from the pole landing gear that Gaui offers, it's a pain not worth the effort.
Make sure your IMU is really secure. I use a thin double sided rubber tape, like servo tape on mine. Works a charm. The IMU already has a very good vibration dampner system for the gyro's so you want to secure the IMU as best as you can.
Make sure all your wires are secure to the frame, also. you don't want anything loose flopping around. I know it sounds like a very small issue, but everything helps.
Congradulations, and good luck!
