Vortex
Yeah....I never thought of thatYou're luckier than me, with a 3S lipo you dont need a 12v converter to run the FPV gear
Ross
Almost got the airframe together......Start fitting up the motors next
Ross
Thanks Ross, Yeah I bet it would be if you were sawing them!!! I have a small grinder fitted with a 1mm thick cut off wheel.......Each shaft took approx 30 secs to cut off and dress.
Done as much as I can now until I receive more parts.......The wait is going to kill me!!! It'll give me time to read up on the electronics and work out which camera platform is going to suit my needs but I am seriously leaning toward the PH PRO200 AV 360 + Retractable gear
I am planning to build a SJ8 and have been doing a lot of researching (time wasted on the computer going round and round in circles) and have come up with what appears to me to be a suitable list of components to fit out the airframe and get it flying. I am going to worry about the FPV components and camera mount when I get this part of it sorted.
I have listed the parts I have come up with and would like to hear any constructive criticisms if there appears I have misjudged something or could have made a better choice.
Lance
Droidworx SJ8
AXI 4120/20 Motors running on 6S
Props 14x7
Hercules II Octo + FC
MK Navi Ctrl v2.1 ME
MK GPS
Interesting...Is there any reading material on the new DJI gimbal??As I have been testing the Retracts and SJ360+AV200 for a while I would recomend you wait for the release of DJI's new gimbals. Keep in mind that I am using a wkm so I need a fast stable gimbal more than you MK guys.
4210/20 are 5s or 6s motors if u want to filt the skyjib. Second herkules suports nominal 20-25 amps per motor, 30 is peak and from my experience axi can pull 60amps spikes wich can burn the herkules board. So have in mind that full gas on the transmiter could burn the board and make your multikopter a flying rock.
Othervise its a nice setup but i would go for same type only faster motors. More rpm/v since this are too slow (hoover is 70% gas with 1.5kg payload on 4s, 5s is little better, 6s would be the best choice and the amps would go down also wich is good for herkules)
Vortex;25591[COLOR=#0000ff said:Anyhow I am not taking any chances with a very expensive pair of boards and plate so I have removed it and sending it back and going to wait for the higher current boards.
[/COLOR]
