need help with my new dji naza
in manual, it does all the same up to the 4 green lights then goes black,,,,, in atti, it goes into a really slow single flash, like every 3 sec one flash, when the battery gets low, it does 2 flashes every 3 seconds
yours is totaly acting like it doesn't have a connection between the tx and the naza
zx12rcarl
No mate that is not my quad in the video.... I just try to say that my naza don't do the 1234 beep thing that's in that video
And was trying to find out if my naza and motors should do that.
from what you saying.... I get the same as you with the LEDs.... But if I try and do the Csc all I get is 2 flashes every 3 sec till
I let go of the sticks and it don't arm at all :(
I get no 1234 beep at startup.... Just beep every 3 or 4 sec from the motors
zx12rcarl
No mate like I said .... I get no 1234 beep from motors on power up ... Unlike the video.... But i do Get all the LEDs you do but when I goto arm motors all I get is 2 yellow flashes every 3 sec and it don't arm the motors.... Then when I let go of the controls it gos back to the 1 yellow flash every 3 sec.
does the light go out if you switch to manual?
that vid never beeped, this was what i saw
zx12rcarl
Yep my led gos off if I switch to manual
At 0.14sec into the video he get 2 beeps then like a 1234 beep.....
When I power up I get 2 beeps but I don't get the 1234 thing.... Just get beep from all motors every 3 or 4 sec over n over
Anyway after my 4 greens I get yellow every 3 sec so try n arm and just get 2 yellows every 3 sec till I let go of controls
And that is where I'm at mate.
must be incompatible huh?
there was a spreadsheet over at rcg on stuff that works and doesn't with naza. ought to put it there if the new esc's just powerup and fly
zx12rcarl
I do think dji need to address this and sort a working list out lol
Well mate thank you for you time an help.... And will post up tomorrow let every one no
If the new esc's work ...
zx12rcarl
:) YESSSS!!!! im up and running.... all thanks to a real good phone call to the bloke at Quadcopters.co.uk.... just like to say a big thanks
for helpin a rite noob out on the phone.
well i got my new esc in the post and cud not wait so i start work puttin them on my quad to find they dont work and was doin the same
think as the old ones lol .... so called quadcoters.co.uk see if he cud help.... turns out the noob i am didnt have the esc`s plug in the right
way to the naza lmao about it now... anyway i set each esc one by one to find i cud only arm motor 2,3 and 4 :(
looks like the 25a hobbyking red bricks are not that good for naza.
anyway i did find a way around this prob by powerin the motors up 1st .... then powerin the naza up... and YES it all works now :) :)
so all i need now is a day of work to go play.... rollon weekend.... that if it dont rain :)
just like to thanks all you lads for you help with this... and if your in the uk and lookin to get into quadcopter the parts and help from quadcopter.co.uk is brill
is it recommended to individually calibrate the esc's that come with the RTF? I was told they dont need to be. this is the only thing I feel I havent done.
now i got my usb driver/hardware resolved I cant keep the heli from violently flipping over. I dont even have a chance to recover it. I cant call this ground effect, something is definitely wrong. Any ideas?
quadcopters
Hi Carl ,
Your very welcome , and so glad your up and running :)
Sometimes its the simple things that are overlooked and I myself have made the same mistakes along the way ... But this is how we learn .
Have fun with the Naza
To Iris, Have you double checked everything is in correct ports ? Usually a flip is caused by FC facing wrong way or a motor wire in the wrong slot .
Not saying this is the case but its worth a double check to eliminate the obvious things.
Geoff
And Geoff you would be right! Duh! I was so focused on everything else I had the FC turned 90 deg. Thanks. Next issue I know i that is going to bother me is that 2 of the motors are very loud and loose. 2 feel "normal" like most other motors I have owned. The problem is even if it flies ok I bet this will add to the vibration when I add my Red Epic, I mean Gopro, to the F450.
