And the answer is...
I just got the CS on the bench for a little diagnostic session and for once there's a concrete, indisputable cause for Sundays aerobatic attempt by a non aerobatic hex. Took the props off, connected a battery, gave the motor start command, 5 motors spin... Hmmmm....
Took the top deck off and checked wiring, all good, wiggle any and all connections, this time the motor gives a couple of back and forth twitches that I've seen before, lost a phase on the ESC. Disconnect the ESC, pull it off the frame, remove shrink wrap, immediate stench of burnt electronics.... AH-HA!
Closer look under a good light and sure enough burnt output FET on the ESC, so we have a cause, ESC failure while in flight. As much as it sucks to have it happen, I'm happy to be able to say I found the reason why. Now I can fix it and move on, a new set of Maytech ESCs on the way to replace the entire set of DYS currently in place.
If anyone thinks a large hex can still fly on 5 motors, I have conclusive proof that it ain't happening...
