Can Naza mlite handle this 12 rotor frame?
karl54
Can dji Naza m lite control this 12 rotor configuration as seen from the picture? my thought is to use the Naza quadcopter setup and connect each "group of three rotors" -as seen from the pic - as a one rotor (I suspect a clear NO, since the motors closer to the CG needs less thrust changing compared to the outher motors) Or do I have to get a pixhawk/other FCs to custom mix motors?
Your help is much appreciated:)!
karl54
im pretty sure naza m lite can only handle quad and hexas
theres no motor mix that ive seen
Thanks! Yeah Excatly! What I wondered was if I could use the quadcopter configuration fromt he control panel and instead of plugging 1 motor into naza mlite, I plug each "three motors" as 1 motor?
