Lipo Battery
If I have 2 lipo batteries, both 6s 10000mah 25c but different manufacturers. Is it possible that one can produce a much longer or shorter flight time than the other?
Yes.
Sent from my iPad using Tapatalk
Ok. Thanks. One more question. What brand of lipo battery would you suggest for a drone. It has to be a 6s. Its for a 700 quad with 400kv motors 13inch props. It flies great but I'm only getting about 7 min flight time with a 10000mah 30c lipo. I'm thinking the battery is crap & I should shop around for a better quality lipo.
JCLs
The battery you have there is badly swollen it looks like. I have never heard of brand you are flying and there is a lot of junk out there. I fly a MultiStar 10000 mAH, 10C, 4 cell battery for about 17 min. on a QAV540G with 11 inch props. If your battery rating was right it should be find. MultiStar is from Hobbyking and they make a 6 cell version. Mine 4 cell ones have done fine. I don’ pull them all the way down either. I also found following
https://www.getfpv.com/tattu-10000mah-6s-25c-lipo-battery.html
And this one:
https://www.getfpv.com/lumenier-10000mah-6s-25c-lipo-battery.html
And https://www.pulsebattery.com/plu25-100006-pulse-lipo-10000mah-6s-22-2v-25c-multi-rotors.html
I am using all of these brands in helicopters or drones and have ended up with these over several years. I would rate Pulse at top based on experience so far but all of these have done well.
Flora
yes, the same frame, different battery have different quality, you may choose the tattu 6s 10000 mah lipo, which was chosen by the red sea movie group.
