Gunter
Draganflyer X4
So I have enabled the gimbal in the assistant, set default settings. Connected the 2 servos to ports F1 and F2. (orange signal wire only) + and - go to a separate battery. When I plug the servos into the power, the main tilt servo just jitters like it's at the end of its tether, the roll servo clicks and then stops. None turn when I tilt the heli!! The servos are brand new, battery fully charged.
Do I have to use the same battery that the heli is connected to for some strange reason?
Any other suggestions? I'm going spare here, my fingers are frozen outside in the shed, and I want to fix this before I go in!
Cheers,
Gunter.
Cheers,
Gunter.
