F
fengshuidrone
Guest
I had all these decals left over after putting my numbers on so I used them in a few places. How did you make your FAA numbers? Where did you put them on your craft? Makes it kinda flashy
Is it going to have a little Virginia name on it like a real plate too? That would be sweet.I plan to make a little license plate and put them on there.
You can even put them in a battery compartment as long as they can be read there.The FAA has a PDF describing "approved" methods of applying our registration numbers![]()
Correct. But, that still means that they can be put there. Minus all the gory detailsyou can only put them in a battery compartment if it can be opened without a tool.
Sheeeesh, I hope they done define your finger as a tool.That's where I put the numbers on the Chroma. The battery uses a depression tab latch for removal. Finger activated![]()
