Announcing the Inspire 1 Battery Charging Hub
The Inspire 1 Battery Charging Hub is an intelligent and automatic charging solution for multiple batteries. The compact design provides multiple charging stations so you can charge up to four Inspire 1 Intelligent Flight Batteries together.
The Intelligent Flight Batteries will be charged one after another, according to their remaining battery levels, with the battery with the highest remaining charge being charged to 100% first. Other batteries will be charged in succession, only after each battery is fully charged. It charges individual batteries to 100% in the shortest amount of time.
The charging process is automatic, and there are LED indicators showing the status of each battery, making charging simple and easy.
The Inspire 1 Battery Charging Hub is small and easy to carry, and it can be used together with your existing Inspire 1 charger and cord. It charges both battery models, TB47 and TB48. It monitors every battery during the charging process, making charging safe and reliable. The integrated port enables you to update its firmware at any time.
When used with different types of chargers, the complete charging time for four TB47/TB48 batteries is shown below:
Specifications
Click here to learn more
SleepyC
www.AirHeadMedia.com
Hope there are plans for one of these that charge simultaneously. Otherwise, what's the point?
Well I mean you could be flying 1, and it will be charging the others. I bet unless you are ripping flights after flights, this would keep you in the air all day.
