How do you guys mount you Gimbale's on DJIF 550s
38super
Hi all
How do you guy's mount your gimbal on your DJI F550. When I had the dji 3H-2D I built a platform in the front ,worked great. But just upgraded to the 3H-3D and for unknown reason's it will not work (weird unsteady movement with 3H-3D ) My next step is to mount right on the bottom but I need retractable landing gear. Looked on line and found no company that build's for dji f550. Can any one point me in the right direction to someone who build's retractable gear for the F550?
Thank's William
Hi all
Thank's William
I use the Tarot rail mounts bolted to the lower frame with 10mm CF rods.
You can extend the rods several inches past the lower frame to hold the camera and gimbal.
I mount my battery on the bottom so the straps hold it all together.
I once use these to hold my landing gear but have since mounted Tarot folding legs on the 550.
haleymon
Mine is like this...
It is mounted to AeroXcraft landing gear... The Gimbal mount comes with it.
