Y6 too heavy?
Hi all,
Just looking to see what others have for flight times with their Y6's. I am concerned about the weight of mine - 1.85kg without batteries, GoPros or gimbals. Throw on 2 x 4500mah 4S packs, and it's close to 2.7kg! It is a very solid build though - 25mm, 240mm carbon arms, and 3mm plate. My flight times - admittedly squirting at 60-85kph for the entire flight - are around 14 minutes (I get too bored doing hover flight tests). This seems low for 9000mah, and I think it's just the weight. The other problem is the 9000mah makes it really top heavy. While it doesn't seem to affect the handling, I am worried about it.
Apart from that, it does fly well, and hovers at around 40-45% throttle (according to the APM).
I have got some 4S2P 6600's coming, which will save me around 300g; I'm hoping this weight saving won't have too much penalty on flight times. Running multiple packs is a bit of a pain too, if I'm honest.
Specs:
Quadframe Y6 Pro frame, with 25mm, 240mm arms, 150mm CF legs.
APM 2.6 with GPS, minimOSD and telemetry
Spektrum AR8000 + TM1000 + Alt & Voltage sensors
6 x Multistar 30A
6 x tmotor 2216-11 (900kv)
3 x 1045 RCtimer CF props
3 x 1147 RCtimer CF props
0420 board cam, and 250mw fatshark 5.8tx
So what flight times are you guys getting, and on what weight and battery packs?
Stacky
I have a Y6 which weighs in at 2.4kg including 5000mah 4s battery, gopro and gimbal. Im using 10 inch props and get 8 minute normal flying flights per battery with my alarm set to 3.5v per cell. I usually land before the alarm goes off.
The weight between 2.5-3 kg is perfect. All you need to check the efficiency and flight time.
I get 11 minutes hover with an ending voltage of 9.9 - 10V using the telemetry and not the Naza battery monitor.
My Y6 Specs:
AUW 2.4kg
Frame- Wooden Simple Copter V 2.0
Controller- Naza M with GPS
Motor- 6 Turnigy 2836/9 motors
Prop- 6 Gemfan 1045 props
ESC- 6 RCManchild 30A ESC’s
Battery (1)- 3S 5000 40C G Force encased battery
Rx- Spektrum AR8000
Add Electronics- Full Spektrum Telemetry with GPS
Gimbal- Tarot Gimbal and mount
Camera- GoPro Hero 3 (no FPV)
Misc,- LEDs
