Although it is against the policy of many I build airframes to dismantle, because sooner or later they all have to be dismantled to some degree and it is just a pain when everything is glued and taped down in inaccessible places. So I use a lot of velcro and double sided foam tape or gel. BUT, for really important things - like GPS masts - I screw them down, usually with a folding bracket to give them some protection when travelling.
Whilst on the subject of GPS masts, I am surprised that DJI has not improved the fixing arrangement. Firstly have they retained the rather loose fitting sockets which you then have to figure out how to fix securely, yet maintain the ability to rotate the puck by a couple of degrees if the MR doesn't fly straight and secondly, with the EVO they have provided a folding bracket for the base but it has a 4mm hole and is therefore too small for the supplied 5mm diameter mast. The top of the mast is still the same wobbly, loose fitting socket. Brilliant.
I wonder why they do not supply a threaded aluminium or plastic mast with locknuts - something I will fabricate once I return to my tools!
