Please help
I will be going fpv on my phantom 2 with zenmuse gimble and gopro 3 black...will use immersion RC 600mw transmitter and blackpearl dual diversity monitor but what can I use as connectors for transmitter so I can take it on and off...I don't want to solder my connections so I'm able to remove easily when not doing fpv?
everything plugs and unplugs at the vtx. mount it with velcro and plug n play. You would still need to solder it in. it needs power, ground and it needs a camera plugged into it. i usually ditch the audio wires, i just unplug them from the immersion plug....
FlyGirl
I could be wrong but I seem to remember that the Immersion RC 600mw transmitter comes with a cable that has the proper connector at one end and bare wire on the other for splicing it in. I like Kloners idea best though. I use velcro too...
JoeBob
Elevation via Flatulation
I'm a big fan of Dual Lock:
http://www.bindingsource.com/blog/duallockvshookandloop/
The rows of plastic buttons in Dual Lock can be lined up the same way each time you position it, so you have a repeatable attachment. It's a positive 'SNAP' when you're hooking up.
And Dual Lock™ has 5 times the attachment strength of a traditional 3M™ Hook and Loop.
You can get single pieces at Office Depot or Ace Hardware for about $5.
I used Dual Lock to make my landing gear/gimbal removable, and to attach LiPos to the top deck with no strap. Haven't had anything let go yet. (I promise to try harder...)
View attachment 16465 View attachment 16466
Hey kloner am I able to shoot video or pictures while doing fpv at the same time with gopro ?
dual lock is some crazy stuff,,,,
you can but anytime you get the photo going it'll make a black screen while it writes...... it will record video fine while previewing and doesn't flash then, it's just photo mode does it
