mini osd setup question
mspaterick
I have a mini osd and was wondering how to set up the wiring. my question is were do I hook the video in camera ground? attached is a diagram.View attachment 16201
You connect to the FPV camera ground. You have to split it to the iOSD mini and your vTx. It is a common ground.
Dean NZ
The grounds can cause ground loops, the PMU is grounded, so pretty sure there not required.
I haven't got mine connected and i have clear video, heard of guys having them, getting bad interference and then removing them and the problem went away...
Dean NZ
thans I will try that What is the LC in your diagram? also how does the camera get power?
I have a TBS Disco Pro, LC s from "IVC Store - FPV Gear" - didn't put it in, in the end - power from the TBS core is pretty clean.
My Boscam T353 is 12v, so draw this from the TBS core vTx power pads.
Dean NZ
what does LC mean? what does TBS mean?
Wiki -LC Filter it will tell you all you need to know and more in effect is a voltage filter to remove any unwanted electrical noise to keep video etc, signal clean.
TBS = Team Black Sheep produce a nice machines called Discovery & Discovery Pro....
