Here's my first quadcopter. I designed the frame it myself, with the idea that I want a platform for a camera, and a clean look. I also like to take inspiration in natur, and make the design look organic, almost like if it evolved into the shape.
I cut the carbon fiber with an electric jigsaw (with a metal blade), about 1mm from the line and then sanded the rest. If you want to do something similar REMEBER that carbon fiber dust is very dangerous, I used both latex cloves, safety glasses and a mask.
The hardware is as following:
4 x NTM 2826 1200kv
4 x Turnigy Plush 25amp
4 x 8045 props
2200mAh 40C LiPo
MultiWii 328P
2mm carbon plate (1.5mm would be strong enough)
14mm carbon tube
Turnigy 9X will be flashed with er9x
I have made some initial test flights, and it seems stable enough. I was concerned that the battery should be pulled way out in the back, but as it sits on the pictures it is in balance.
I working on making a 3 axis camera mount that will be mounted in the front.
The first outdoor test can be seen here:
And now for some pictures:
All my parts ready for the frame
The printed design is attached to the carbon with double sided tape.
Then cut with the electric jigsaw
And sanded to final finnish
The legs. Assemply has started
Some heat shrink tupe was put in the pipe to make it fir, now it can't turn.
View attachment 15234View attachment 15235
The frame is complete
Wight is okay, is was hoping for something under 400g
Total just under 1kg, I think the total lifting power of the four motors is just over 3 kg, so no problem here.
View attachment 15238View attachment 15239
4 x NTM 2826 1200kv
4 x 8045 props
2200mAh 40C LiPo
MultiWii 328P
14mm carbon tube
