[SOLVED] HF Pro Arming Troubles - Purple Flashing Light
Hey all,
New to the Multirotor forums. I posted a version of this question in the RCGroups Hoverfly forum with no reply, but this looks like it offers more active Hoverfly support.
Spent four hours today trying to configure a quad that has flown well with the Sport board but was replaced with with a Hoverfly Pro board. Same ESCs, no change there. Downloaded the latest Hoverfly Firmware Client Update and loaded 4.8 into the Hoverfly Pro. Followed the two requests to set DIP switches which appears to have loaded firmware twice (once for each of the two possible settings).
These are my issues:
1. The new Hoverfly Firmware Client didn't allow me to select the configuration (X,+, quad, hex, oct, etc.). Seems that this latest software skips that tab - I assume this is okay?
2. Power up of the HF Pro starts with a short flashing green, then flashing purple light - unable to arm. I have no AUX1 connection (only gear for auto level and gain settings). Therefore is it safe to assume that altitude hold is not enabled because I've made no connection from the receiver to the Hoverfly Pro PCB?
3. Unable to connect to the Setup utility. This should work because the board connects (USB drivers work fine) to the Firmware Client just fine. It detects the COM port and then scans all prior ports in a cycle.
I feel that I should really know the troubleshooting better than I do, considering I work for Parallax and we sell loads of the Open boards. But I'm really struggling and would appreciate any help. I've read that the purple flashing light is an arming problem by AL or AH being enabled, but AL is disabled and AH is not connected.
kgracey
Hey all,
kgracey
