EDIT: These converters only work with PAL cameras
http://www.hobbytoys77.com/aerial-fpv-hdmi-to-av-analog-signal-converter-for-sony-nex5-nex7_p2702.html
Ultra light aerial transfer with HDMI AV module
Explosion struck another masterpiece, Happymodel FPV micro single aerial brushless Yuntai necessary light volume for Sony NEX series tailored ultra soft silicone line directly connected graph transmitter installed micro single no trouble to think how to get.
Designed for aerial and a general design requirements of the ultra light HDMI AV of weight and volume, digital to analog module
HDMI D interface in line, compatible with most of the miniHDMI standard interface equipment, direct camera is powered, no external power supply; directly connected graph transmitter, without HDMI line
Ultra light weight is only 4G
Using this module, HDMI output mode the camera must be set to AUTO automatically, otherwise it may not be the correct output
The module factory have all through the detection, line welding, any human caused problems led module cannot use are not returned.
Another: the module for PCB, HDMI interface is inserted into the space between the PCB board and the camera is about 2mm, more than 2MM protuberance near the camera HDMI socket to be unable to use this module, for example, Panasonic GH2, within the HDMI module has the lock, if not removed, the HDMI module is not available. The test of Sony Nex5 Series 7 series is fully available, the camera needs to be validated in other.
