I was in a crunch and bought some semi used gens ace lipos.  The IR is around 10-15/cell.  I can balance charge them to 4.2/cell and they seem to hold which is good.  But Im not sure I like the high IR reading.  I also impulsively bought some Zippy lipos the guy said they have less than 10 flights and the IR is around 10/cell.  Are these all shot or do some lipos just start higher?  I've always just flown a pack until they cant hold an even charge of less than .2-.3v per cell.  So in other words if one cell reads 4.17 I get a little worried if I cant balance it out.
On another note, specifically the icharger 206b, when you are in the special modes and looking at the IR, if you go a page over it says a bunch of numbers that look to be per cell voltages.  They are listed as 4.12-4.18v/cell.  I got worried and put the lipo through another balance charge cycle just for half a minute to see what the voltage reading was.  They were 4.2.  So now I am very confused as the reading on the charge cycle says they are all at 4.2 yet this other page is saying 4.15-ish.  Any ideas?  I wish I had the icharger before but I am new to it.
edit: so, in reading the online manual I see that the reading I am referring to was the idle output voltage.  Should the charge voltage and idle output voltage be closer to each other? Usually if I can charge a lipo to 4.2/cell it will read 4.2/cell on an external volt meter. I don't get it.
