I need help. I somehow messed up big time.
I ignored everyones advice about hooking up the LED to the battery. Quite a lot of people online said it won't cause any issue.
I have 2 LED colors, red and white. Two of each on the booms and two of each on the motor mounts. I soldered these together, that gave me a bullet connector for negative and positive, this picture shows you the corresponding PDB connectors:
My Wookong-M comes with an XT-60 connector for power. So I soldered a corresponding XT60 connector to my board:
I connected all my motor bullet connectors to my ESCs bullet connectors.
My PDB came with 2x power cables with 6mm connectors, I removed these and added 4mm connectors corresponding with my batteries.
I did not yet installed my Wookong, I wanted to see if my LEDs were working. So I plugged in the battery. Working, I heard some beeping, probably the ESCs, but almost simultaneously SMOKE. I unplugged my battery directly, but I think harm was al ready done. It kept smoking for a little while, so I guess some ESCs ended up for the bin.
Please help me to understand this, what did I do wrong? How can I test if an ESC is still working? I connected the positive banana adapter from the battery to the power cable, then I did the other one. The minute I touched the other side, it gave a little spark.
I am totally lost now - Probably something stupid but I lost a lot of money with this mistake.
Any help is much appreciated. I would love to see some pictures from someone elses PDB as well, might give me a clearer insight.
