Heya Bart,
Aye, flying the IBCrazy Ultras on 1.3, 2.4 and 5.8! Was going NUTZ trying to figure out the difference between the bluebeams, mad mushrooms and cloverleafs forever. Finally found out that the "Ultras" are basically a set comprising of 1 Cloverleaf TX and 1 Mad Mushroom RX and are only sold as a set! The only real difference is that the RX is the 5 Lobe Mushroom instead of the Four Lobe. I run diversity on all of these pairing up the Ultras with a set of IB Crosshairs. Right before I killed the Disco, I ran out over a mile on the 2.4 cross hair straight ahead... Coulda gone farther but lost my nerve and turned it around. Heres where it got nuts. I brought it straight back and still had battery so I left the crosshair pointed forward and turned the bird 90 degrees left to run out solely on the mushrooms. Another MILE!!!  Things flat work. There is a null direct overhead and flying straight overhead fast and behind sometimes means a second to hook back up but so far this combo and the Ultras in particular have outperformed all other combinations! (PS thx Kloner for the setup!!)
Pls bear in mind the Disco was also on ezUHF... these things DO have the range to easily outfly the standard RC
I've got a BOX of patches, yagis, helicals, clovers, fans, even an IB Skyhammer... (I've got problems..) The Clover/Mushroom "Ultra" combo rocks!!
